Flyfisher
- Norfolk, UK
I've not been completely ignoring the hints for some progress photos, though I confess it has taken some time to get around to sorting some out. Anyway, without further ado, here is a little of what I've been up to over the past few years.
Here are a couple of 'before' photos. Actually, because the white is a bit washed out the render looks in better condition that it actually was. The second photo shows the condition a little better. Needless to say it was cement render and had to come off anyway. It's also not really possible to see where the roof was leaking in multiple places, though the poor condition of the dormer windows is apparent:
This photo is after the roof had been stripped, timbers repaired and a membrane installed, together with rebuilt dormer windows and a new chimney above the roof line. Not really much to show for a great deal of work, but it certainly banished the damp feel from the interior of the house as well as the buckets in a few strategic places:
A few years later (when funds had been replenished!) it was re-rendering time. This was not a DIY job so I was able to sit back and watch others work for a change. This photo shows the underlying structure. Much of the original wattle & daub panels were intact (and were not disturbed!) though it's also possible to see where the previous 'vandals' chopped the original timber frame about in order to insert the Georgian sashes. As far as we can tell, the frame dates back to 1550 and we think the totally inappropriate windows were inserted when the C17 addition to the right was built. The original timbers were in very good condition, though the sole plate to the left of the door had to be completely replaced due to being covered by concrete for many decades. The sole plate to the right of the door was in better condition and only required partial replacement. Fortunately, it was fairly easy to reduce the ground levels, though winter halted the final landscaping work to the front of the house.
This is a 'during' photo taken after the first scratch coating of lime render. Not particularly interesting really:
And this is the final result after limewashing. Well, not the final, final result as winter halted any further work, but really only needs a bit of landscaping work to lower the ground level in front of the house (I'm planning a sort of 'gravel moat' along the front) and re-positioning the surface water drain so that I can remove the temporary flexible down pipe and replace it with a cast iron downpipe, plus a final touch-up of the black plinth. A large part of the C17 wall (under the lower roof) was dismantled and rebuilt and substantial new oak lintels added over the two main windows, though they are a little hard to see now that everything has been limewashed. I managed to get two coats of linseed paint onto the woodwork before the weather turned against me, but it was in fairly poor condition and will need a bit more work this year, but at least everything was protected over winter.
So, about six years of work (ok, not full-time - I had plenty of other projects on the go as well!) and the old place doesn't look a lot different than it did in this 1908 photograph - which is how it should be I suppose.
