A
Anonymous
Guest
hello, i was hoping for a bit of advice about relocating the sockets in our 1890 terrace. Currently the sockets are stuck onto the skirting at floor level. This means i cant put furniture near the room edges and it can be tricky to get plugs into the sockets because they are so close to the ground.
I want to put them in near flush with the wall ( i presume they should go into the wall rather than the skirting even though it is quite deep. Do i have to pull the entire skirting board off so i can sink the cable into the plaster behind? if so whats the best way of doing this without destroying the wall.
any advice appreciated. as you may be able to tell i am a complete DIY novice.
