All,
I hope you may be able to shed some light/give some advise as to my next course of action. I have recently had an offer accepted on a turn of century brick built property in East Sussex (Brighton). The property is end of terrace and it’s suspected that the main walls of the building are 9” (225mm) solid brickwork. The walls externally are rendered which are painted and conceal the wall construction meaning there is no visible insitu damp proof course.
I have commissioned two individual damp proof reports but after reading quite a few articles on this forum I am in no doubt they will all come back suggesting required work. The first report which was (strangely!) commissioned by the Estate Agent, apparently they do this as standard for the majority of period properties but my doubt is that it was done after a previous survey identified the requirement.
The main areas of concern I have, taken from both the initial two reports (awaiting detail from the last which is being completed today) and a number of viewings and inspections by my self and family are as follows. It is worth noting that the property doesn’t smell of damp and there is no visible sign of damp walls on the ground floor. It is of a standard 2 up 2 down construction with a hallway against the party wall separating the living room and party wall:
-The first report has identified through the use of a Protrim moisture meter that there is proof of rising damp and subsequent preventative damp proofing is required along all accessible areas of the party wall and some area of the internal wall between the hallway and living room. Due to cupboards and fittings in the kitchen it was not possible for the report to include the remaining stretch of the party wall into the kitchen, this is obviously of some concern as the main reason given for the rising damp is that “the adjoining property ground levels are higher than the subject property internal floor levels” this would seem to suggest that the complete length of the party wall may need preventative damp proofing is needed at all?
-The second report has not identified any remedial damp proofing required on the party wall, but has identified that the whole internal wall between the hallway and the living room needs treatment.
-One of my major concerns is as to why three walls within the Living Room are dry lined. Although this is a commonly used method to legitimate DIY’ers/Builders etc? Obviously this dry lining prevented the walls being tested internally for rising or penetrative damp during the any reports, is my only way of investigation this to do/get done a drill test? The current vendor says the walls were dry lined when he bought the property 8 years ago.
-There is also some gable end damp staining observed in both bedrooms from what seems to be ongoing and / or historical rain water penetration (according to the report). I am inspecting this separately but wonder if potentially cracked rendering on the gable end wall would amplify any potential damp problems, letting in water and trapping it behind the render.
Any views or ideas on my best method of attack would be greatly appreciated, I am under considerable pressure from the Estate Agent about moving forward with a survey which I am arguing will give me no more insight as to the (potential) damp problem on the ground floor.
Kind regards,
Lloyd
Kind regards,
Lloyd
