Nimster
- Sheffield-ish
Afternoon
We're hoping to do some building work on our house. I'll give you a brief description of the house as it's fairly confusing and may help when you look at the plans. The front part of the house is Victorian. This has an extension on the back (built in stone, same as the house). In the back garden, at 90 degrees to the house, we have 2 x farmworkers cottages that have been knocked into one building. These are also built in stone and are from around 1750 (we think). The previous owners built a passageway to connect the front house to the cottages. With me so far? Good
Our plan is to open up the back wall of the extension to the Victorian house to put in french doors. We also want to change the passageway as it currently has white upvc cladding at the side and top, and a clear plastic roof. As the building is listed, we need to consider the aesthetics of any changes, as they'll impact on the view of the cottages (since the passage joins onto them). The CO has said we can do pretty much what we want inside the Victorian house, but we have to get the french doors and new passageway past him.
So, my question is, which of the following two ideas do you think best? Please bear in mind that the passageway door shown on the first plan won't be there - we've been told we have to lose that. The passage will just be a run of windows. The windows will also be 2-over-2 sashes, not 6/6. The first plan is the original and has sash windows on the passage and a higher roof line (same as we have now). The second plan (my rehash) has single pane windows to match the french doors (so the modern additions are clear) and a lower roofline to expose as much of the cottage as possible (cottages are on the left of the passage, just off plan) and to fit under the extension roof, making it look more like a porch, less like a continuation of the extension. The passage will be built in stone with a pantile roof, same as the cottages and house. Any thoughts, suggestions, etc are very welcome.
Plan 1 - the original
http://www.photobox.co.uk/album/album_photo.html?c_photo=94058684
Plan 2 - the rehash
http://www.photobox.co.uk/album/album_photo.html?c_photo=94058685
Many thanks
Nim
Plan 2 - the rehash
Many thanks
Nim
