Deal All,
We're moving into a ca. 1900 brick-built house that has some rot in the ground floor sub-floor timbers. Blocked air bricks and gully are probably the main reason. While yanking up the Corydalis that has grown against the wall, I found clear polythene between the soil and the wall, though the inch of polythene sticking up was looking ragged. There is a lot of efflorescence on the surface of the first course of bricks above the soil level and polythene.
I've spent a lot of time on the website, so I get the idea of letting old buildings breathe. But is this polythene helpful or not? The house is prone to subsidence and leaning down the hill, so there may have been a reason not to make a proper French drain. The wall in question is the footing of the font bay, which is not integral to the structure of the building, but is hinging away from it a bit.
So! How does it work out? Is breathing important even below soil level? I suspect it must be, otherwise eveyone would do this polythene trick instead of making French drains. Can anyone comment?
Thanks very much for ideas, and for all the posts before,
Adrian.
Adrian.
