victorianjob
We are having to re-point the entire house as a lot of the mortar has worn away. I've asked the brickyard to use lime, however I've just found that the mix he has been using is 6:1:1. Sand:lime:cement. I read I'm the Victorian House Haynes manual that a bit of cement can be an acceptable compromise. Does this mix sound alright? There is an awful lot of pointing done, do I continue or ask the brickyard to change his mix?
Btw it's Victorian house constructed from wire-cut red bricks.
Sorry for offloading so many questions!!
