Anne
- Monmouthshire
I need some help with the recipie for lime mortar to go around a new door frame. I've refused all damp courses, foam and other icky things and intend to point out the tiny joint between the frame and the wall. I thought Hydraulic might be the way to go as it will get some water in heavy rain when gutters are overwhelmed. Whatever I use has to be soft and not overly wet. I thought maybe 3.5 mixed 1 to 1 might make it softer and help with any water problems. We're putting a drain pipe outside to help take the water away. So idea's for what mix to point out narrow spaces and deal with some weather would be very helpful.
Thanks in advance
Thanks in advance
