fernicarry
- Argyllshire
A couple of weeks ago, after the hot weather, I thought I'd have a poke at the windows in the hope that there might be something salvageable with some hardener and filler. It was worse than I expected ... much worse.
I've now had a couple of guys round to quote and we're looking at 8 new sills, 8 sets of pulley stile repairs and between 4 and 7 new sashes depending on how keen they are to repair as opposed to replace. Only one sash still has wavy glass and both are willing to make an attempt at saving that. I think all the downstairs ones must have been replaced in the not too distant past judging by the colour of the wood, most likely by a large national company beginning with V...
The bit I'm struggling with (other than the cost...) is the pointing between the window frame and the stone. Its dressed sandstone around the openings with about a 1.5" gap between the window and the stone. Over the years its been patched, filled and over-painted to the point that the paint line now overlaps the stone and its all cracking and delaminating and generally very unsightly. Both would rake it all out. Guy #1 wants to fill the gap with expanding foam with a trowel applied mortar over that. There is a gallery image on his web site that looks very neat. Guy #2 wants to use a modern gun applied mastic and then recommends overpainting. #1 would be fine except for the expanding foam obviously.
So I suppose I'm looking for ideas on how best to back fill the gap before putting a finish on top? Another thread here recently suggested expanded metal of the sort used by plasterers. I can see that working but not a tradesman wrestling with it. Whats actually in there at the moment, at least on some of the windows, is a sort of foam sausage (backing rod?). Whilst not ideal, this is at least easy to remove in the future since its just held in by friction and shouldn't be too time consuming for a tradesman to apply. Any thoughts? The same foam was under the sill and in its defense it was absolutely bone dry.
Secondly, I do want to get the paint line back to the window frame rather than over-painting the mastic. Whats a good approach to removing the existing paint on the sandstone? Will chemical strippers like nitromors work without causing damage? The paint does seem to come off reasonably easily with a bit of chipping but thats probably because a thin layer of sand comes off with it.
Thanks all.
Thanks all.
