Having had a few previous questions answered very well on here, I need your advice again. We live in a 200 year old cottage (not listed) and someone previous to us has pointed up the outside (random stone) in cement. i am aware of the issues this causes and in recently renovating the house we had it plastered with Limelite internally ( again i know you will say i should of done it in proper lime however it came down to money and time). There is no problems with damp at all however the outside face of the house on the weather side is disintergrating quite badly in places.
My question is this, would you recommend me taking this cement out, the few areas that have come loose anyway looks like pretty good condittion lime mortar, which i guess somebody not knowing better thought was worn cement. If i leave it i guess its going to get worse, but i am likely to give myself problems by trying to remove whats there, the cement has been pointed up pretty badly anyway.?
finally as a completely seperate subject, i have recently started having problems with my water pipes. artound 0200 - 0300 every morning when no water is being used, we get a very loud knocking for a few hours from the water pipes. the only solution is to turn the stop cock off before we go to bed. This problem only arose about 6 weeks ago in conjunction with some work on a local main. the water board say it may be because we have an old lead pipe coming from the main to our house and this noise is passing up at night. has anybody heard of anything like this before. we are having a nightmare at night time with no water, or being woke up if we forget to turn water off. PLEASE HELP.
