JoceAndChris
- Lincolnshire
Carpenters! We're about to order the wood for our tent room project, and can't quite decide what thickness and type. Any suggestions?
The shape of the ceiling is to be an inverted pyramid, created with solid panels that are supported by the long pieces running round the walls.
The panels will be covered with cloth. (as will the walls)
As you can see the pitch is shallow due to the window height which we didn't want to crop. The plan is two put up two long rectangles to make an apex ceiling, like your normal tent. And then to fit in two perfect triangles of wood to turn it into an inverted pyramid shape.
The first image in this link is an inverted pyramid ceiling, I think.
http://www.fauxology.com/2012/03/tented-ceilings/
Thanks for any thoughts on which wood to order.
