Hi everyone, no doubt you'll all be getting bored with my questions soon
I am soon to be installing a hot water system into the house we are in the process of buying. What I'll be doing is essentially moving around and adapting the current system albeit with all new pipework and cold water storage tank. The current setup includes a hot water cylinder which takes up half of the kitchen (i'm not exaggerating, it has its own plasterboard room)! + a bathroom that is a part of the 60's extension to the rear of the property. We are going to be changing the current bathroom to a pantry/ storage room and fit a bathroom to one of the upstairs bedrooms.
The setup is an vented cylinder with a cold water tank heated indirectly by an oil boiler. The water pressure isn't great enough for a unvented cylinder and to be honest I'd rather have a system that I can personally work on and maintain without calling out a "specialist" every year for a checkup.
The main question I have is that I would like to keep the hot water cylinder down on the ground floor. My understanding is that this wouldn't be a problem as it is only the cold water head that needs to be kept as large as possible. The hot water cylinder will be next to the oil boiler for simplicity and space reasons.
The second question I have is that we have a beautiful 200ltr freestanding roll top to fit in the bathroom. The bath's cold will be mains fed whilst hot water is from the cylinder. I'm going to buy a new cold water tank anyway so I know exactly when it was fitted and how old it is. Would a 150L tank be sufficient for this? I'm not 100% sure on the size of the hot water cylinder at present but it's not a small one!
Finally, (thank god I hear you say) We plan to fit a gravity fed shower with it's cold supplied from the cold water tank via 22mm pipes. Would the proposed 150L cold water tank be big enough for this purpose or should I just fit a biggun/ piggyback a couple of them just to be safe?
Below is an image of the setup I plan to use. Can anyone in the know confirm this would be ok or give me a slap? I haven't included any of the heating circuit into the diagram other than an expansion vessel to show it's a sealed pressurised system.
I really appreciate the help - This forum has already been an invaluable source of information and advice.
