Hopefully a quick sanity check:
Having some problems with air admittance in the plumbing system. Set up is roughly as follows:
Subject to further investigation with the camera, the airvent seems clear (was up on roof today, plumbers snake disappeared down to its full 3m length, and several watering cans of water disappeared down quite happily.
The bathroom at the top of the stack is rarely ever used - the bathroom on the left of the sketch (downstairs) is the main one. When particularly large "debris" is passed, or a lot of toilet paper is used, there is a good old gurgle from the sink and shower pipes, but enough water remains in the traps to avoid smells. Seems to be the simple answer that just an air admittance valve (AAV) installed in the pipework for the downstairs bathroom would be the answer.
However, two things are giving me a slight pause for thought:
[li=1]
[*] When that situation happens, the water level in the upstairs bathroom also gets pulled down so that the upstairs starts to smell of sewer - this would imply that the upstairs vent is blocked, which it doesn't seem to be.
[*] After one particularly "impressive" flush, air came up the downstairs sink so violently as to create a mini fountain in the downstairs sink for a second or two :lol:
[/li]
Only change to the plumbing system is that the mechanism in the downstairs toilet has been replaced with a modern one, which has a considerably more powerful flush action. It might be that the more extreme symptoms were just the new flush clearing some previous partial blockages and normality may ensue?
Am I now just overthinking and need to get on a whack an AAV in - or are there more pressing issues?
[li=1]
[/li]
