skier-hughes
- Staffs, UK
Can I run the waste from a downstairs wet room shower, along with the waste from the sink underground to join the waste from the toilet?
In short, the downstairs toilet blocked, in trying to clear it noticed water coming up from outside, dug up concrete to find that the clay waste pipes had cracked.
They also went uphill before they went down to the inspection chamber, and they weave round like intestines!! Due to the fact they used to go to a septic tank and then changed to mains drainage, but didn't take a direct route. See picture,
All the toilet waste is underground.
Adjacent and connected to the waste pipe is the waste from the sink, toilet overflow and a washing machine, in the utility area. This goes into a p trap level with the surface, with the 3 waste pipes discharging into the p trap from above.
Jo has ruptured her achillies tendon, and finds it hard to get over the lip to the normal shower tray, so we thought we'd install a wet room by extending the toilet room into the utility area.
The floor of the wet room would be level with the ground level now, but obviously draining to one side.
This means I need to dig up the concrete floor that is there now to fit the new shower floor, but can I dig a channel and fit the waste underground in a similar fashion to the toilet waste, with the waste from the sink connecting into it half way along?
I'm not sure what'd happen to the toilet overflow in this scenario though??
I've also looked at sites like screwfix but cannot find any type of fitting to take a small waste pipe to a large one.
The sink connection isn't essential, I just thought it'd tidy up the outside, but I can't see a way of having a below floor level drain going in to a floor level waste
I'm currently digging up all of the old clay pipes so I can dig down so that it falls from the house to the chamber and takes a more direct route and thought I'd gain some help if possible to give me some knowledge and gauge whether it's a job I can do, if I need to call in a plumber to sort it or I'm breaking all of the rules under the sun.
