I'm planning to use wood fibre board insulation on internal side of the walls for the kitchen and bathroom that leads off it. Lime plastering over it. I've never used it before. I can see posts and information about cables (ie using oval conduit fixed to the wall). What is the approach for plumbing? I could try and minimse the amount of pipes on the external facing walls but its not possible for all of the pipework.
A possible solution I was considering is to put a stud frame at the bottom of the wall. The skirting would then cover this frame. Hoping the pipes wouldnt get too cold being fixed to the external facing wall. Any issues with this? Is there a better way?
