charlie-ia
- LANCASHIRE
our house has "ruled ashlar" concrete render which is fairly firmly attatched to the sandstone walls which are mortared with lime. i think the render is from around 1916.
my plan is to repair and fill using lime, and leave the rest alone.
am i right in thinking that i should fill the render cracks with a hard lime to try to match the strength of the render?
or should i use something softer, to match the strength of the mortar?
some of the cracks are settlement cracks that go into the wall.
should i use 2 different mixes?
how do i test the hardness of the original materials?
if i matched to the cement would i use a strongly hydraulic lime?
is this what a "natural cement" is?
any tips on matching what i need to use to match an original mortar?
i heard that crumbling some up in a jar with water was good, but i cant remeber if i was supposed to add vinegar, and what all the different layers show. and i think if you left it a certain amount of time it told you about the clay content. oh, i wish i'd paid more attention!
im still not sure wether or not to take off a layer of render around the bottom of the wall. would this provide much benefit to letting the wall breathe?
theres a window that has been blocked up, but cracks in the render show where it is, and have allowed water through to rot the floor of the bedroom.
if i just fill the cracks is that all i need to do? they dont look very big from the outside.
would you try to remove cement patches that were not exactly attatched to the wall, or would you leave it be if it wasnt in danger of falling off?
