My house was built in 1905 The south facing external 9 inch solid wall was DPC injected 15 years ago (before I lived here) and the inside was re plastered 4 ft up from the floor.
Now the damp and salt deposits are right up to the ceiling and extremely damp in the corners where the chimney breast meets the wall. You can dig the plaster off with a tea spoon with little effort. The outside ground is about 18 inches below the floor level,
My neighbours property has had leaking guttering for about 2 years which floods the alley dirrectly between my and his property but don't understand why the damp has risen so high. There is no drainage in the alley. I've spoke to him several times but he doesn't seem to want to do anything about his guttering.
ventilation seems to be ok ie there is loads of original air brick type things which seem ok. Do you think its worth getting the drains inspected which run along the alley paralell to my damp wall there are two mine and his and is this expensive ? Ps forgot to say the outside of my wall has been rendered at some point in history. What can I do about my neighbors guttering ?
