Fizzer
- Oxfordshire
We have a wall that has been damp for a while. It's external facing and ground levels are low outside. However it's been rendered on both sides way back in 1960. It is the front wall of our house.
I'm carefully removing the internal render, the bricks are very soft and easy to damage. I've found two bits of wood in the wall where bricks should be, they have turned to dust (you can see one of them in the lower right corner of this pic).
There's also a long piece of wood above the lintel which is spongy and full of woodworm holes, It disappears towards the room next door so I don't know how long it is yet.
The render outside of here has diagonal cracks (hairline) from the corners of this window and the one above it. the wall on the left is a wattle and daub wall.
The adjoining wall on the right is made of blocks so we assume that it is a 1960 wall. We uncovered this large crack in it:
This goes all the way up to the ceiling of the 1st floor but doesn't appear to have a matching crack outside. i *think* that it hasn't moved much in a long time.
Our survey doesn't really mention this part of the house at all and I'm not sure it's actually moved much for a long time. However it all looks a bit iffy to me. Should we get a pro in to take a look? If so, who would be our best bet?
Also by drying out this wall/wood too quickly could we cause problems?
Is there anything we should do now to help prevent problems in the future.
