meljones35
1802 cottage - any ideas on best light switches and plug points to replace 1960's ones currently there?
AMc said:I'm a supporter of good quality white plastic - the brass effect plastic looks terrible after a while (or straight away to my taste) and the more vintage stuff is no more/less in keeping but substantially more expensive - esp. if you're doing a whole house.
Make sure that the range you get covers all the things you need as mismatched white plug sockets/aerial points/phone points/network points draw your eye in a way matching ones don't IMHO.
AMc said:That's very pretty. I bet it's an absolute pig to fit that well in an actual wall though![]()
JoceAndChris said:Here's a cheap Screwfix socket behind lovely Jim Lawrence antiqued brass Regency pineapple lampstand. I hope you can see the discoloration in the switch - these are due for replacement with better ones, but it's a real pain as the back plate is deeper on the quality products, so it's going to mean hacking out, and replastering, and repainting in sections.
...off the edge of the photo!JoceAndChris said:the Jim Lawrence antiqued brass version just disappears...
Right click -> View Image works for those with sensible browsers...Penners said:...off the edge of the photo!JoceAndChris said:the Jim Lawrence antiqued brass version just disappears...
LadyArowana said:Vey good point. I remember having these "invisible" ones on my wish list and then hating the sockets that were part of the range and worrying that I would need other fittings that were not available. I went with white plastic, but the range that had little covers to go over the screw holes, builder made me help fitting them as it was not a job for big hands.
