I live in a Georgian flat which is 200 years old. In the hall the walls and ceiling are pretty bad and there is a mixture of plasterboard badly merged with old together with other bodged bits.
In other rooms I have had the walls and ceiling lined and painted and they turned out fine. They were in better condition. I am not averse to a few lumps and bumps here and there.
What are opinions on plaster skimming a wall in an old house. Should this be done and can it be painted directly over or does it have to be lined as well? I have seen it done in a victorian house and the finish was good. Should I be asking what type of plaster they will use? Normally I would just have lining paper but I do not think the finish will be very good as there is too much filling needing done.
