Hi all,
been following your discussions and stories for 6 months now since starting in earnest to "repair" our late C18 brick built farmhouse. Figured it is now time to introduce ourselves and ask a few questions
The property is our family home where we have lived for about 6 years and was "restored" in the early '80's including covering everything in portland cement based render and plaster, replacing half the wood windows with uPVC and injecting a chemical DPC! :evil:
The house is actually in very good condition, but isn't "breathing" terribly well and has had a lot of original features played with or spoilt for what seems to be cost or speed reasons. Our main aim is to secure the ongoing strength of the fabric of the building (repointing/repairing walls that are suffering from being "damp prooofed") as well as sympathetically promoting orginal features where possible.
One of the minor projects (and one I can do at this time of year) is repairing/extending an internal partition and door in one of the rooms that was installed in the 80's. Like everything in the house it has been done just by nailing up some plasterboard and painting it, no skim or anything. As we are going to replaster the room in lime having relieved it of the portland I want to plaster the partition as well to match so when I paint (limewash) it is all matching. I also want to make the partition a bit more solid and soundproof.
So, intended spec is a stud type wall using heraklith on both sides sandwiching a layer of Kingspan or similar then plastered in lime.
Couple of questions:
1. Any problems/concerns with the above approach or alternatives you would suggest?
2. Anyone found heraklith at local suppliers as opposed too by the pallet from Skanda?
Thanks in advance and look forward to talking to you all over the coming months.
Cheers, Paul.
Cheers, Paul.
