pineapple
Renovating an old limestone cottage. The outside has been covered with something or other and painted so probably not breathable (I know I know). There was a major damp issue on the first floor gable end internal wall - in line with the chimney flue. We hacked off all the plaster to that wall and carried out chimney repairs ncluding fitting flashing :!: That seems to have stopped further water ingress and it is drying out. At the moment the stonework is damp down the first 3 or 3 foot from the ceiling and 1-2 foot across.
The chimney/stove guy has recommended that the wall is left as long as possible (whatever that means) then plastered with lyme plaster followed by renovating plaster. However the builder doing most of the work is adamant that we can dry line the wall and moisture will still be able to escape and I will have a useable room in the meantime. I don't want to make a problem worse but on the other hand don't want to live with a building site forever. Advice please!
The second issue is that before I had even heard of lyme plaster, another bedroom was completely replastered in standard plaster.
Just wondering if I should go for a breathable paint such as a clay based one or whether it is a pointless exercise over ordinary plaster.
Cheers
Cheers
