hi there
we are the stage of rendering and plastering half of our house, we have removed the cement render from outside put on a breathable membrane, batons then lath, on the inside we have filled in between the timbers with sheepswool and are ready to start putting on the oak lath, just wanted to check should we be putting anything onto the sheepswool to protect it from the plaster or just simply put the lath straight over.
one other question, we have laid the limecrete floor, which will eventually have underfloor heating and a limcrete screed over, we want to use flagstones but no one seems to be able to advise on a breathable adhesive, can we lay them into the screed as we do it, then use lime to mortor the joints.
thanks
thanks
