I had an escape of water above my lounge and a lot of the water made it through the light fitting and as the room was dried the plaster ceiling rose which is about a metre in diameter is parted from the ceiling at one side. there is also a small hole in it where the screw has parted from the rose.
When the insurance surveyor saw it he said through the hole is a copper screw and it will just screw up, so no problem.
I have just got up a stepladder for a look and can't see how it will just screw up and can see when I pushed it back into position there is a lot of weight on the light fitting.
how will this be fixed?
