worms
 - ultima Thule
I think I need a Plan B…
The property is a rubble construction farm building, converted to a dwelling in the 1940’s, internally plasterboarded with no insulation. Externally it appears as originally intended and in places where I have had to remove small bits of plasterboard in the past, the walls behind the board have been standard rubble. In winter the walls remain pretty cold and condensation in the bathroom leads to mould growth on the external wall. Plan A was to remove the plasterboard from the bathroom wall, and replace with wool insulation and lime plaster to give a well-insulated breathing wall that used the rubble wall as part of the overall heat store/insulation.
On removing the plasterboard, I find that, because of the window opening that must have been inserted in a previously blank wall, the wall is of brick and cement construction, two bricks thick (placed lengthways so 18 inches thick). Good news is that everything is nice and dry, but no way is it going to breathe!
But what is my best move now? Stick with plan A, battens, wool and lime with no air cavity? Or should I do as per the thermafleece advice, leave an air gap then membrane then fleece and new plasterboard? There is no air brick or equivalent ventilation to the outside and the floor is concrete so any air gap will have very little air movement.
