Flyfisher
- Norfolk, UK
I'm about to finalise the fitting of a boiler stove in a large inglenook fireplace. The installation requires a heat-leak radiator to be connected that will work by gravity convection in case of a power cut stopping the pump that will normally circulate the hot water through the associated heat store. This will necessitate two pipes to connect the stove to an upstairs radiator and an attic expansion tank.
Rather than break through the side of the inglenook and have visible pipes running up the wall into the upstairs bedroom, I would like to run the pipes up the chimney and drill through into the bedroom, where they would go into a cupboard beside the chimney and therefore remain invisible. From inside the cupboard they can then continue into the attic, so a very neat and tidy installation.
The inglenook is about 2m x 1 m and tapers quite slowly, so is very spacious inside the actual chimney. The stove will be connected to an insulated liner and the pipework can be easily kept well away from the liner. The length of the pipes above the register plate will be less than 2m before existing into the bedroom cupboard.
The installer says that such an installation would be acceptable as far as regulations are concerned, but has advised against running the two pipes inside the chimney because of the residual soot inside it, which he thinks will cause the copper pipes to corrode.
My thinking is that it should be possible to wrap the pipes in a suitable lagging and then cover the lagging with aluminium tape, thus completely covering and protecting the pipes from any soot/tar contamination. Because of the size of the chimney, the pipes would be easily accessible from a step-ladder to do this.
What does the panel think?
