Zebra said:The best wood filler I've found is to take some sawdust from cutting or drilling the same floorboards, sieving it to remove any lumps, and mixing it with PVA glue. When it dries it can be sanded, matches the colour of the floorboards almost imperceptibly, and is very hardwearing. If you are not cutting or drilling those boards, then could you find a wood of a similar colour, and make some sawdust?
Penners said:I've always used a two-part resin filler, like this one:
http://www.screwfix.com/p/ronseal-high-performance-wood-filler-white-550g/45077?kpid=45077&cm_mmc=Google-_-Product%20Listing%20Ads-_-Sales%20Tracking-_-sales%20tracking%20url&cm_mmc=Google-_-Shopping%20-%20Sealants%20and%20Adhesives-_-Shopping%20-%20Sealants%20and%20Adhesives&gclid=CjwKEAjwzdGxBRC3rPWZq83FzyUSJAB9IC5i05-XiZK5vs1m_ZbGhvNQwvgQd9V8RGNcQTCyjp0EwRoCVkzw_wcB#product_additional_details_container
It hardens by chemical reaction in about half an hour, after which it can be sanded, drilled and painted. It's sort of pine coloured, but if you don't like the colour you can colour it with felt-tip pens (choose indelible ones so that the colour won't be removed if you lacquer or varnish over the top). If you're filling knot-holes it's quite fun and effective to draw a knot pattern on to the filler.
Mix in the hardener very thoroughly, but don't mix more filler than you can use within about 10 minutes, as it will harden before you can use it. And don't be tempted to add more hardener than they specify, otherwise it will harden too quickly and be wasted. Apply the filler very slightly proud of the hole, then sand it down flush after it's hardened.
chuckey said:" mixing the different colours is quite fun too! " Especially when you do it on raw wood and get a 99% colour match. Problem comes when you varnish the lot, the wood goes 3 shades darker, but the paint does not.![]()
Frank
