Finally got around to taking some pics and transferring them to the PC.....thought i'd share a quick pic of our place. This the the rear elevation...the main house was built in 1780, with the annexe to the left of the pic built in 1830. From the deeds and inspection of the brickwork etc. it appears that there used to be a glass construction on the rear of the house (in the centre of the main building)...I assume that this was some kind of orangery?
Not that funds permit, or that we need the space....I personally think it would spoil what is a nice elevation - what do you think?
Other points of note:-
1. The roof used to have a flat top (you might see a slight change in pitch halfway up). It was comandeered by the RAF as a spotting point during the war. Apparently, there were lots of leakage problems and at some point the roof was pitched. We still have a set of stairs in the attic which appear to go nowehere now.
2. There used to be a window on the first floor in the middle....this has been bricked up at some stage (the brick colouration is different). Inside, an internal wall has been inserted (L&P...so some years ago) and this would have run through the middle of the window.
Lots of other pics now on my PC, so will try to find some time to post
