Flyfisher
- Norfolk, UK
If I have an old (Georgian-like) window frame that is really beyond repair, is it possible to have a replacement made that can accomodate double-glazed units? I don't mean overlaying wood onto a large double-glazing unit to make it look OK (as if!), I mean a like-for-like replacement except for being slightly deeper to accommodate multiple DG units.
I've read that it can't be done because of the thinness of the wood between the glass panels (not sure what these bits are called
), but I don't really understand why this should be.
I do realise that any new glass wouldn't have the same character as old glass though. Are there any companies that make crown glass anymore, and shouldn't it be possible to make a DG unit from such glass?
Or is the thought of adding DG to a period property too heinous a sin to even consider - even if it looked the same as the original window? Surely it must be more acceptable than that dreadful secondary stuff?
