Feltwell
- Shropshire, England
Here at Feltwell Towers, the Wi-Fi signal works fine in the main body of the house but won't stretch out reliably to the end of the old scullery (where the kid's game console is) or the garage (which is, believe it or not, a bit of a pain - taking the iPad out there for internet guidance when fixing things is invaluable).
Our router is a BT Homehub 3.0, connected up to the BT Infinity fibre broadband, I've checked and there's no way to add a better wireless aerial to it that I can see. Relocating the router also isn't really an option.
For all you techies, what's the best / cheapest way to extend the WiFi coverage? I've seen kits like the below - although I do wonder if there are cheaper but still reliable non-BT options. The power circuit they are connected to, does it have to be the same ring main? Ideally I'd have one unit plugged into the upstairs bedroom ring main (where the router is) and the other out in the garage, which should also get the signal to the scullery - but which is of course on an entirely different power circuit, in fact the common point isn't even at the main consumer unit for the house, it's at the meter where the power comes into the house, my garage having it's own consumer unit.
http://www.shop.bt.com/products/bt-...se&utm_term=Wi-Fi_Home_Hotspot_500_Kit Phrase
Or - I've seen this sort of plug-in thingie which a forum I've read got it to work OK with a BT Homehub 3.0. Presumably with this it needs to be within a reliable wi-fi range of the router in order to work.
http://www.amazon.co.uk/TP-Link-TL-...1388922069&sr=8-1&keywords=tp+link+tl+wa850re
Please bear in mind my level of technical ignorance on computing & network matters!
