Penners
- Suffolk, England
Period property restoration is frequently all about blending the new with the old.
There, that's my excuse for this topic dealt with! :wink:
A friend who lives in France is restoring an old farmhouse and two smaller outbuildings, which he is turning into "guest rooms". He wants to lay on electricity, telephone and satellite TV supplies to both the smaller properties, fed from the main house. So he'll be running mains cables, coaxial cables and phone cables from the main house out to the two buildings, running underground. Internet connections from the small buildings will be made through his house router, using "Homeplug" powerline devices, and the satellite TV signals will be fed from a single large dish with a multi-head LNB.
That's the background - here's the question. He will be running these various cables underground, housed in flexible plastic trunking. Will it be OK to run all three cables - mains, coaxial and phone - in the same trunking? Or will there be interference problems from the mains cable to the other two services? If it's better the run separate lines of trunking, will it be OK to run the coax and the phone together in one, with the mains in a separate trunking?
The distance from the main house to each of the smaller buildings is about 80 - 100 metres.
All thoughts and advice gratefully received.
