wobs
 - Hull - there's a nip in the air.
The idea that we use less water per flush, when getting rid of our poo is an issue that has long been discussed among academics, intellectuals, and select dinner parties for decades.  OK, maybe not.
However, industry is failing in providing the best solutions for our toilet needs.
We recently bought a new toilet, hoping to get a traditional design, and fitted with a syphon flush. This is a key point......
Here in the UK, the syphon flush had been the only mechanism allowed to flush a toilet for over a century. Then in 1999, to come into line with the EU, dual flush toilets were allowed for the first time. Everyone cheered, as a new era of efficient loos were introduced, where a “number 1” only used a small amount of water.
Except it was a false dawn.
It turns out the dual flush toilet is a flawed design, as the system is based upon a two valves. The first to fill the cistern up, the second to release the water for the flush.
The thing about valves is that they will eventually leak. Even the best ones will eventually let water through. This means that unless you keep it maintained (and not everyone will), you will be wasting more water than you would otherwise use.
I have seen dual flush toilets waste copious amounts of water, but they will leak for a long time before the untrained eye will notice, as a small leak will be too small to notice.
http://www.elementalsolutions.co.uk/wp-content/uploads/2012/08/wcs.pdf
-This link gives a flow of 0.04L/min being an un-noticeable flow to the untrained eye. This equates to 57.6L per day wasted. Add to that the amount of poorly maintained toilets where the leak is easily visible (something I have often seen), and it is clear we are being sold a con.
People are buying dual flush toilets under the assumption that they are buying something very efficient, but it is only true for a limited time.
Compare this with a syphon flush, which cannot leak in this way. The only valve in a syphon toilet is used to fill the cistern, and that is closed by the filling of the cistern. When a syphon unit needs repair it is because it has stopped flushing, but it isn’t leaking. This is usually down to the diaphragm.
Our shiny new toilet (a low level, lever operated design) was ordered on the assumption that it was a syphon system, but it came with a dual flush mechanism operated by the lever. Sneaky gits!
However, I wasn’t beaten. You can still buy siphons. And not just single flush, but variable flushes:-
Saver Syphon:
-I ordered this, and instead of a flimsy diaphragm at the bottom, it comes with a flap, which should last much longer, and the variable flush works very well, as it is an air valve, which stops the flush when you release the lever. Not suitable for close-couple toilets.
You can retrofit a normal syphon flush with an Interflush kit made by the same company. I had this on our last toilet in our previous house, and worked well for many years. It enables you to adjust the timing of your flush cut off as well. Clever stuff.
And the Turbo88 available from most plumb supplies is a dual flush syphon system. I don’t like this personally, but that’s just me.
The ES4 toilet comes fitted with the Turbo88 apparently
Saver Syphon:
