LadyArowana
Yes folks, it's that time again.... Shed of the Year http://www.readersheds.co.uk/
atticman said:Don't talk to me about sheds!!
I'm in the process of going through a few hundred pounds of Planning Permission costs because I have the temerity to want to put a shed up in front of my house, at the bottom of the garden, behind a 1.5m thick, 2.5m high privet hedge!
Penners said:I may be out of date on this (as with everything else) but I was under the impression that a shed doesn't need Planning Consent or Building Regs, as it is classed as a temporary structure.
Mind you, I suppose if you're building your shed on some sort of foundations, this might nullify that classification.
Can anyone clarify this for me, please?
If it's within the curtilage of a listed building, it will need planning permission, but unless you are doing work to the LB as well, it will not require LBC.Keith Bowman said:Penners said:I may be out of date on this (as with everything else) but I was under the impression that a shed doesn't need Planning Consent or Building Regs, as it is classed as a temporary structure.
I can't clarify it, but I can add that putting it within the curtilage of a listed building can mean the full rigmarole of site plans, elevations, colour, LBC etc.![]()
Planning permission is needed for a shed if it is in a conservation area.Penners said:I may be out of date on this (as with everything else) but I was under the impression that a shed doesn't need Planning Consent or Building Regs, as it is classed as a temporary structure.
Thanks GH and everyone else.Gareth Hughes said:If it's within the curtilage of a listed building, it will need planning permission, but unless you are doing work to the LB as well, it will not require LBC.Keith Bowman said:Penners said:I may be out of date on this (as with everything else) but I was under the impression that a shed doesn't need Planning Consent or Building Regs, as it is classed as a temporary structure.
Similarly, if the shed is going to be between a house (unlisted) and any public highway or open space onto which the house fronts, it may well not be permitted development.
Zebra said:Planning permission is needed for a shed if it is in a conservation area.Penners said:I may be out of date on this (as with everything else) but I was under the impression that a shed doesn't need Planning Consent or Building Regs, as it is classed as a temporary structure.
http://www.planningportal.gov.uk/permission/commonprojects/outbuildings
Zebra said:Well good luck. Our local planning department, instead of responding to a friend's planning application in the supposed 8 weeks, has taken 28 weeks so far and he still hasn't got an answer!
Surely the planning department's letter of acknowledgement will detail the timescale of the council's response, and the recourse available to the applicant if that timescale is not adhered to.Zebra said:Well good luck. Our local planning department, instead of responding to a friend's planning application in the supposed 8 weeks, has taken 28 weeks so far and he still hasn't got an answer!
