another_richard
- South coast
Victoria 1880s terrace down 'ere in Hastings not listed.
Last 6 of about 100 houses in the road to still have wooden sashes.
All sashes are 2 over two. House is ex-rental so lots of the original glass has been 'removed', lack of putty means more rattles than a Alberta bush.
Window by window I plan to fit secondary glazing.
In a fit of pique I bought wood 70mm x 34mm for the frame and 25mm x 18mm for the beading.
I plan to essentially create a frame (1520mm x 1080mm) using the wood and purchase x 4 (4-6-4) double glazed windows to slot in (£60 for four panes).
My dilemma is time - We have a bearn 1.5 years old and he commands all of my attention when I am with him. My wife is doing a PHd and so the time I have him she studies.
Time is very limited.
Me:
I left school many moons ago and I did a C&G in carpentry but have not really picked up the tools in years, instead as an archaeologist I now do CAD and GIS. So using my very old skills I had grand plans to rout nice edges, create mortice and tenon joints sash clamp them together etc but no, orders from 'she who must be obeyed' says get it done in as little time as possible.
So instead of the joints etc I thought of two screws and a splash of glue. Given that each single dg unit (approx 65cm x 45cm) will weigh a considerable amount 7 things became apparent before I start:
1 Will the screws hold the finished frame/panes together?
2 Will I be able to easily lift the window out once Spring comes?
3 I did plan the magnet acrylic plastic sheet route. Although a favourite with my wife I feel x 4 dg units at a total cost of around £60 was comparable to 4mm sheet of plastic at around £40+ I am guessing I cannot use the magnet strip to hold this in place and will have to use screws? Sounds like a silly question but I'll add it anyway.
4 Should the bottom two dg panes be toughened = way out of my price range? Base of window is less than 90cm high from floor level.
5 Can I just squirt low modulus silicone into the frame and insert the dg pane then seal again with the silicone and apply the beading? Or will it require glazing strips and/or lms?
6 The distance from the parting bead on the sash to the ogee architrave is about 60mm so the secondary glazing will stick out a bit. I can live with that but does the gap between my new frame and the sash have to be a minimum distance to improve sound/heat insulation?
7 On each of the 4 panes should I leave a little trickle vent. I would essentially drill a 2mm hole under the beading. Am I on the right lines and/or is this required?)
One final note: My plan was to insert new dg panes into the existing sash by routing out from the inside this would essentially make the window triple glazed. But, given the weight of the new dg units I feel the existing sash could not take the weight. Is this correct?
Thanks for your time.
another_richard.
Me:
another_richard.
