jocelyn plummer
- North Norfolk
On Sunday evening I turned the radiator stat down from 6 to 3 because the drawing room was too hot. Next afternoon I noticed that the room and the rad was completely cold, ( to be expected if the room temperature was ok), so turned it up to 6 again to warm the room again. It stayed cold. Assuming it to be an airlock I politely asked OH to bleed the rad, which he did, checking all the others at the same time. Fine, I thought, all will be well now the airlock has gone.
An hour ot two later I checked rad, still cold, water all over the carpet by the valve which was mysteriously hanging loose------- I will leave the rest to your imagination and suggestions as to what happened next.
However, now the valve is back in place the rad is still bl***dy well not working...... all the others are. Any helpful suggestions would be useful.
PS we have taken energy readings every week and have logged 75% less than our provider has been charging us for----------boiler ticks over at 50 and I use the stats to control each room. Gas Esse has been running on idle except for cooking, but does give a gentle ambient heat in the coldest part of the house.
Girls, if you want a job done properly, do it yourself, and whatever you do, don't ask the Navy to sort it out.
