mattice
- Worcestershire
I've had great success in drying out my back wall and an internal wall sharing the same small 3/4 height cellar by lowering the external ground level and ventilating with some air bricks. I intend to practice my lime pointing on the wall and foundations I've exposed. However I'm now stuck with what to do to reinstate the ground levels. Here's a picture (please excuse the mess, many projects in this picture!).
The ledge (it probably has a name) is mirrored inside and supports the internal floor timbers, previously the ground was a couple of inches above this in places. There is probably a further 3-4ft foundation below that already exposed so I'm relatively comfortable with my excavation. Whilst the soil is generally clay, in this area it's very free draining, I suspect several decades of ash have been deposited here.
I'm considering going down six courses, laying some 100mm deep footings, offset from the wall, and building a 4 course retaining wall topped in some blue bricks from the garden, effectively leaving a 200mm gap. This would create an evaporation zone with some membrane and large stones at the base. A lot of forums suggest putting concrete at the bottom of this and draining it away somewhere - this doesn't feel right. Even a French drain is proving difficult to fathom as I have a sewer to the septic tank running parallel to this wall acting as a barrier and all my surface water drainage is too high!
Is this a sensible solution? Does anyone have any other ideas for dealing with the ground level? Do I need to drain my 'evaporation zone' or can a rely on it naturally draining? I'll probably reinstate this area to lawn, or a gravel path. I've seen a previous post using crates where a path is butted against the wall but I'm not sure it'll work for this job.
On a related note, I've just started probing ground levels at the front of the house by two concrete slabs revealing a pool of water and some sort of brick structure underneath.... :shock: We have slate floors and I suspect the water is making its way through the wall and under the slate along the path of the mains water pipe, to an internal wall which is my last remaining damp mystery! Some pics for amusement before the sledge hammer comes out
