Penners
- Suffolk, England
I'm astonished to tell you that BT have recently finished installing fibre to our telephone exchange and our street cabinet, so we're about to get Infinity broadband. As of next Wednesday, our broadband speed will increase from about 2.5 Mbps downstream and 400 Kbps upstream to around 35 Mbps and 9 Mbps respectively! Wha-hay!
I'm amazed that this service has reached us, out here at the Back Of Beyond. I know that they're rolling out fibre to much of the country over the next two or three years, but I imagined that they would be concentrating on areas of high population density. Ours is around 3.5 farmers per square mile, so I can only assume that someone, somewhere has some pull! Still, gift horse... mouth... and all that.
Anyway - to my question. I shall be asking the engineer to connect the new router to our main phone socket by running a cable through a couple of walls The location and path of the holes that will needed for this is quite critical, so I want to drill them myself, before the engineer arrives. Can anyone tell me what sort of cable he will use to connect the router to the socket? I presume it's not just ordinary telephone extension wire - could it perhaps be an Ethernet cable? And will there be plugs on the end that will need to pass through the holes, necessitating larger holes than are needed just for the cable? Or would he crimp on the plugs after routing the cable?
Any and all information gratefully received.
