FamilyWiggs
- Flintshire, N Wales.
Just a quickie...
Was just replacing a ceiling rose, and just to check I'd isolated the circuit before working on it I touched each terminal with the dreaded screwdriver tester (yes I know they are dangerous and evil - but they're convenient for this type of task). This is not one of the neon-testers but has a little LCD display giving an indication of voltage.
As expected live lit up 240v, and neutral didn't. Surprisingly, earth lit up something approaching 110v.
Rechecking with a multimeter showed 240v on live and 0v on earth - which was somewhat more reassuring.
I'm assuming that it was just getting some sort of induction from the adjacent live cables to the earth? Am I right in thinking this is more likely if the earth isn't connected to earth at the other end? Do I really need to go and do some continuity testing?
Thanks,
Robin
Thanks,
Robin
