I would love some suggestions on how to find someone to help me fix the significant penetrating damp that appears internally at the end of each wall tie on a weather facing wall. The 1800's cavity wall has a sandstone block exterior with occasional sandstone block set at 90 degrees, which ties the exterior sandstone to an interior low quality soft brick wall.
I have moisture being drawn in through the sandstone tie blocks more rapidly than it evaporates internally. The result is a lot of visible condensation.
Any thoughts?
Any thoughts?
