perelytik1
Hi,
I am a newbie to this forum so please be patient. We are in the process of buying a mid terrace cottage circa 1840 of stone construction with a stone slate roof. The surveyer identified damp, so we had a company to come and give an estimate.
Here are the findings form the company.
The accessible walls at ground level were tested with the aid of a protimeter and the readings obtained. These together with visual observations made, indicated the presence of rising damp and low level penertrating damp to certain wall.
He is to install a chemical damp proof course and tanking the wall up to 150mm then applying a Limelight to the rest of the wall.
From what I understand chemical injection doesn't work on solid stone walls. surely if he is tanking the base of the wall it won't be able to breath, is that correct? Also I read that the meter he used doesn't measure actually damp! is that correct.
Reason for posting is I would like to get a decent contrator who is sympathetic to old buildings and identify exactly what is causing the damp. could anyone point me in the right direct.
The property is near Huddersfield West Yorkshire.
I thank you in advance for your help.
