biffvernon said:(There were ice flowers on my window this morning.)
I must say, I thought that situation already existed.Flyfisher said:(b) allowing DIYers and other unregistered installers.... to employ a third party qualified electrician to inspect and test their work as an alternative to using a building control body (see paragraph 36).
Very sensible I think, but what's the practical difference between the current situation whereby a qualified electrician may be prepared to certify DIY work?
There is no regulation requiring you to use red/black cable to extend a system that already includes red/black cable. All you have to do is place the following sticker on the consumer unit:Flyfisher said:I could presumably have legitimately used brown/blue cabling for all the lighting I installed instead of using up my old stock of red/black cable.
Well, that thought did occur to me, but I dismissed it immediately as completely beyond the bounds of possibility.Feltwell said:I suspect that FF's use of red/black cable is more to do with proving that his work was done before the recent regs
