tjrhs
- West Kirby
Howdy all.
We live in a Victorian semi, solid wall construction. The insulation is generally poor and the house leaks heat, but the kitchen is particularly bad. It is north facing with external walls on 3 sides.
I want to put internal insulation on the external walls (I've those marked in green below) as part of a planned renovation which will include knocking a wall through to the adjoining room (marked in blue). But I don't want to insulate other rooms either next to or above this one because I can't afford it and don't want to lose original internal features.
I'm no expert on insulation but understand you're supposed to wrap the house to avoid cold gaps. So if I get the builder to install a breathable insulation with lime render to the marked walls will that mitigate that problem? Or do I still risk moisture issues at the edge/border of the insulation? If so are there any other solutions to allow a single room to be tackled?
Any tips really appreciated.
Tom
Tom
