Anne
- Monmouthshire
I need some advice with this one. I’ve just purchased a ton of Hydraulic Lime mortar to be used on a chimney stack which is looking worse for wear as well as a couple tons of per-mixed non-hydraulic lime to be used for pointing. There is tons of tons of pointing to be done and it will probably take years before I’ve done everything that needs to be. With that said my question is what I use to mix or knock up this stuff.
The Hydraulic lime is probably a one off use for just this area as its very exposed to the weather, but I’ll be knocking up non-hydraulic lime for years to come do I really need to spend £1,000-£2,000 on a pan mixer? Do I have to have a pan mixer for the Hydraulic mix as that is not pre-mixed? Should I rent one for the Hydraulic and buy a hand mixer or cement mixer for knocking up the pre-mixed non-hydraulic? Help please.
