edi2367
- Edinburgh, UK
I have recently started replacing cracked mastic around window frames where timber meets the stone. I have done 1 window so far and used stone coloured trowel Mastic from everbuild. In the spec sheet it says only to use oil based paint to paint once hardened.
Is there any reason why I could not use water based exterior paint?
Is it not going to bond to the hardened surface of the mastic?
Thank you
Thank you
