Pennyviz
- Wick, BS30
Hi
Have stripped woodchip off walls and filled any holes with ecomortar R50 - good stuff sticks well but very rough finish, bit like sandpaper.
I gather from Earthborn website that for normal lime plaster you should allow 1 week per 1 mm for plaster to cure before painting with claypaint, and from what I can gather from Ecomortar suppliers this is more like 1 day per 1mm for Ecomortar.
What happens if you don't allow this time? I understand it doesn't carbonate but what does this mean in practical terms - does it simply fall off the walls? Is there a website that explains the process that anyone can recommend?
For future reference, If I was to put a finishing lime topcoat on top of the ecomortar to get a smoother finish, would this work?
