About 4 years ago I got a builder to remove the cement render from my barn (rubble stone walls) as it was flaking off anyway. I asked him to render it using lime as I thought that was the right thing to do. Little did I realise that most builders don't understand lime and it now transpires that he used a lime and cement mix. I don't know what proportions he used, but there must be a reasonable amount of lime as the render has whitened with age. Unsurprisingly, there are now a few cracks. Also the wall is a bit damp. I think the main reason for the damp is that the render is quite absorbent - it is easily wetted by the rain but dries out well, too. Some of the damp is, I think, caused by condensation on the cold walls (bare stone inside). I think the solution is to reduce the capillary action of the render without reducing breathability. Two solutions have been suggested to me and I would appreciate comments or further ideas:
1) Paint it with silicate paint
2) Apply limewash with pva (first coat) and add linseed oil to improve water run-off
I know that some may say "knock off the render and replace it with lime render", but this isn't really an option as it is stuck fast - removing it would damage the wall. Also, I think it is a fairly breathable mix - the problem is that it is excessively hard, hence the cracks.
As regards the condensation, I presume the best solution is to lime plaster the inside of the wall.
