Andrew Bodenham said:I've found that a hot air gun is much the best way of getting the majority of the old paint off window frames. Beware of fumes and fire risk. Yes, it's easy to crack the glass if you're not careful - masking the area locally with a sheet of metal can prevent this. But for working right up to the glass I use that highly under-rated paint removal device viz: the scraper. This can be a purpose made tool with replaceable blades, but I prefer to use a cabinet scraper or a stripping knife. The key to success is to keep the edge sharp with a file used every few minutes.
External paint usually just needs a good rub down to remove the accumulated dribbles of years. I've had good results with a power sander, but if dust is a problem then coarse wet & dry paper used wet can be helpful, especially for feathering in around flaked / stripped areas.
After all that stripping just make sure you use a good paint system. Now that's a whole new thread....
Many paints cover about 12 square metres to the litre. This stuff does about 24.Antwerpman said:It seems expensive but it goes a LONG way as you only brush it on thinly.
Oh yes, just think about never having to clean a paint brush again. Of course if you did want to clean it you only need soap and water.Antwerpman said:you just stick your brush in a jar of linseed oil in between coats so no need to worry about washing brushes etc.
