harkerhill
Hi all
I'm trying to plan out work that I need to do on the house over the next few years and save up appropriately...
So, the works that I need to get done are/is;
- remove render if possible to return to brick - or remove render and re-render in lime if brick work is bad
- replace roof slates and underfelt - currently slate but really bad condition and felt is very britle
- replace guttering - mixture of cast iron and plastic - want to standardise - not sure if cast iron is still recommended or used?
Does it matter which order that I get the above done in?
Thanks in advance for any help!
