JanJonWestWales
- Carmarthenshire + Cardiff
Not wanting to open a huge debate, but something has been occupying my mind.
Are there possible downsides to lining a chimney?.
Our Welsh farmhouse has a traditional "sime-fawr" huge Inglenook.
It is my understanding that originally this would have been pretty much alight 24x7, and would have emptied the room of damp air continuously up the open chimney
ie; with properly breathable walls - a properly breathable house....our holy grail
I assume it would have been similar for other occupied rooms (although not sure how the bedrooms would have worked)
I sometimes wonder if we have buggered up this mechanism?
In the modern way, we have installed a log burner, a tall flue pipe, boarded and insulated the inglenook ceiling, and of course an insulated lined chimney flue up to a top chimey plate.
We have of course used lime render inside and out, so at least we have the breathable walls, but where is that moisture going to go???
Surely a closed fire isnt going to suck much damp air into the fire, and up the flue?
Some heat will leave the room up through the chimney, but it wont be taking much moisture with it . That's insulation for you.
Not that I am going too...but shouldn't I remove the chimney lining, open up the inglenook, just have a flue pipe from the log burner up into an open chimney, and let the warm air + moisture flow upwards?
Very inneficient from a heat loss perspective,but great for damp control.
any thoughts?
http://blaencwmbychan.blogspot.co.uk
any thoughts?
