I have what I think is an old ceramic urinal trough. It’s approximately 4ft long by 11 inches wide by 6 inches deep extending to 9 inches deep where the back fixes to the wall. It has a drain hole at one end about 2 or 3 inches dia. with a small mound in front of the drain which I presume was to stop the fag buts going down the hole. At the other end there is an inbuilt lead pipe connection for flushing. Apart from its size and shape its construction is very similar to the old Belfast sinks i.e. very heavy and robust with all the exposed surfaces in a white ceramic glaze, the hidden surfaces (back and underside) are a yellow buff stone colour.
My problem is that this trough comes in two halves each half being 2 ft long forming the overall 4ft length. One half has a male connection moulded into the yellow buff stone, the other half has a female connection so both halves butt up perfectly together without sliding apart. I guess it was made like this just so that it could be lifted. Each half is extremely heavy.
I plan to mount this trough on an outside wall using some salvaged decorative cast iron brackets but I need to know what would be the correct cement/joining compound to join the two pieces together. All the modern plumbers and builders merchants can only offer “mamby pamby” plastic fitting adhesives which wouldn’t last five minutes on this beast. I’m sure that the old Victorian upright urinals in public toilets had a very dark cement in the joins of their various components but perhaps this was just grime. Any suggestions?
