Sadly we got caught up between planning and building control and ended up rebuilding rather than repairing our old end 1700s terraced cottage.
To be honest the repair would have been a bit of a trigger's broom job, the cottage being cement rendered straight onto the timber frame in the 1950s or 60s so almost all wood of structural note had deteriorated to either dust, or simply fell off when the internal decorative coatings (hardboard, asbestos sheet, wood panelling) were removed - leaving the building literally held up by a skim of cement render. Of the original sole plate, a princely 10 inches was all that remained and the main beam in the centre of the property had rotted away from the ground up so that the bottom of it was suspended about two feet from the floor.
The suspended floor over bare earth had been filled up with the filth of the ages, so that the filth had comlpetely filled the void and was touching the underside of the floorboards, rotting it all away - the solution employed here at some time in the past was to simply lay a second layer of joists and flooring over the top of the first one, with rather predictable results.
So the point of the story is - I have a number of old wooden posts that are no use to me - I couldn't re-use them as the BCO wouldn't allow it for structural purposes, they are no use decoratively to me so what can I do with them? They all show signs of woodworm at some point in the past, although seem to be fairly strong. Most have a tenon joint at one end and various nails of the ages in, out or through them.
Are they only good for fire wood, any better suggestions, or if anyone can collect from Essex and make use of them they are welcome to them..
There are also a couple of longer posts with the sockets for the tenons in but they have been out in the garden all year, where as the posts above have at least been kept in the man-shed.
As an unrelated aside, I have several hundred sq m of reclaimed oak strip and planks that are surplus to requirements now - bought "rather too much" at auction so if anyone needs some reclaimed oak flooring (it needs some love - it's probably not ready to lay) I'll happily sell it at cost
-Steve
-Steve
